09-20-2003, 07:43 PM
Oil pan? Oiling for 2.5 t2?
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
I'm building up a 2.5 common block t2. Now without balance shafts there's one pretty big oil pan sitting under there. Is oiling an issue? Without the balance shafts more sloshing, oil moving around and not staying in the pan. Would it be better to use a 2.2 common block pan? Will a 2.2 common block pan work, as long as you use a 2.2 common block oil pickup?? Anyone sell 2.5 common block oil pans with a windage tray or something like that to keep the oil where it should be?
