10-29-2003, 09:04 PM
#107
Originally posted by spoolboy
Wonder what would happen if I threw both a stock turbo and my spare stock G head on?
Things that make you go Hmmmmmmmm.....
Low vehicle weight, a good tune and a decent chassis are pretty amazing.
I am happy with my Stock G head so far.
Give it a try!
-Bryan
10-31-2003, 10:20 AM
#108
My Ride: 91 Spirit R/T
Engine: TIII
I've been keeping tabs on this thread since I have been doing this same conversion. I just got done with the swap and I love it! Right now it doesn't matter that the power may be less at high RPM than a similar 2.2; there is power everywhere in the powerband compared to the old tired 2.2. Getting onto the interstate is no longer a laborous chore but a couple second effortless jaunt. Judging by my asselerometer, 4-5 psi is equal to 8-10 psi on my old engine(200K miles). I'm only running 4-5 psi until everything is broken in and bugs worked out. The engine is a basic stock rebuild '89 2.5L, standard sized bearings and pistons, stock 782 head, '89 TBI roller cam, 2 piece intake, +20 injectors, ported exhaust manifold(really just a cleanup aside from the 2 lumps that were taken down), an A-555 transaxle, and all packaged in an '86 GLHS. I'll report back with some dyno runs that I hope to have done in the next month or so. Maybe play with some cam degreeing and boost levels at the dyno. I hope to see 200 WHP with 16-18 PSI. If I don't oh well, that means I'll need a larger exhaust!:big grin:
10-31-2003, 10:21 AM
#109
Engine: TIII
10-31-2003, 12:02 PM
#110
Nice times Spoolboy, is that real 1/4 mile or 1/8th mile converted. Thats impressive considering I can't even get close to that, is your car gutted? and how much boost?
As for shifing, my van won't shift till it hits the limiter as I have to fix my trans but when I backed out and got it to shift at 5500, it went faster and I broke into the 14's. As for power, after 5000 ish it just signs off, no point keeping it there but will address that this winter!!"thumbs up
10-31-2003, 03:25 PM
#111
My Ride: 1987 Shelby GLHS 189
Stock to stock, you should expect to see that... especialy given the comparison of a "tired" 200K motor to a fresh one. Freeway merges shouldn't be "laborious" even with a stock TII in a GLHS...
When the modding begins and the "artificial" limits for boost are removed... the watters get murky...
10-31-2003, 06:42 PM
#114
Thanks, nice work on the car "thumbs up
