10-04-2003, 06:55 PM
My Ride: 91 Spirit R/T
Engine: TIII
Machinehead is right any machine shop worth a darn will number the pistons and then hone each bore to the specific piston that will be going in. That's for any bit of competition use. Around here if you're building a lame-o SBC 350, etc. they measure one or two pistons and hone all cyliders to match them. Hone to match is the key there.
Aren't the letters to signify the number of tenths the bore/piston deviates? Not tenths of an inch but tenthousandths, .ooo1"
10-05-2003, 03:53 PM
Originally posted by csxt#10
i would like to know also.what would the c and d,s be
- A size 87.442 -87.455 mm
- B size 87.455 -87.468 mm
- C size 87.468 -87.481 mm
- D size 87.481 -87.494 mm
- E size 87.494 -87.507 mm
These are the sizes listed for the pistons, I have that info already.
It doesnt tell me where "STD" (aftermarket) pistons fall in that range but I would assume it would be the E sizes.
(after all, you can only make the bores bigger, not smaller, and if it was based on an A size, then someone with an "E" bore would have no way to seal it properly)
10-05-2003, 07:13 PM
My Ride: 1987 Shelby GLHS 189
Sean, aftermarket pistons are based on an 87.5mm "stock" bore size. My .020 overs are 3.464" Straight from Wiseco the MFG.
10-06-2003, 12:25 AM
piston sizing
Sean, they are based off of "A" size. Since "A" fits into an 87.5 mm block bored exactly 87.5 mm
All pistons require clearance. The E piston would not fit into a perfectly bored from the factory 87.5mm block because it is 87.507
The aftermarket pistons are based on bore size. You have a .020 over block and they make the piston to that bore size minus any clearance they require. Forged require more clearance than cast
A Forged piston is smaller than a cast piston made for the SAME bore size because it expands more and will "fit" the bore when warmed up to operating temperature
If the finish honing was perfect at the factory and not a productiion line there would be no need for A,B,C,D,E pistons....there would be only STD
10-06-2003, 06:21 AM
Re: piston sizing
Originally posted by GLHS0658
[b]Sean, they are based off of "A" size. Since "A" fits into an 87.5 mm block bored exactly 87.5 mm
All useful info. I didnt even notice the second E number exceeding 87.5 nor was I factoring in the pistons rings.
However, if that is true, the blocks with E sized bores wont seal as well as the block with A size bores.
As for overbore siz, it still has to be based on some base number (which turns out to be A, which was the question!). When they send you the pistons it has to be .020 over some given size. (which turns out to be STD, or A?)
Yeah, they had manufacturing issues back then. :\
04-25-2005, 12:26 AM
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
This post is old; can anyone confirm that this information is correct?
