Old 10-10-2003, 04:20 PM   #1
crankshaft differences?
3W MO78
Is there 3 kinds of crankshafts? 1. cast 2. forged and 3.billet I've just heard that the intercooled 2.2 had a different crankshaft then a non intercooled motor. Am I being fed a bunch of hoowy and there are only two cranks, and if so I guess I need a 1988 forged crankshaft #2 rod bearing is screwed on mine.
Old 10-10-2003, 06:25 PM   #2
Re: crankshaft differences?
Just 2, no billet.
However, the 89+ cranks are different. (not stronger, just incompatible)
OmniSRT4 is offline
Old 10-10-2003, 07:41 PM   #3
thank you!
3W MO78
I have heard so much conflicting info that I thought that I'd come to the source for all things TD
Old 10-14-2003, 09:55 PM   #4
so if you have common block.. and want to use a 2.2 crank in it.. can you use an 8 bolt crank or does it have to be.. a 2.2 common block crank?
boostaholic is offline
Old 10-16-2003, 08:41 AM   #5
Well aside from that question not making any sense....I will try and answer anyhow.
The CB crank *is* an 8 bolt crank, but so are the later model non-CB's. Hence why the question isnt making a lot of sense.
The difference is the size of the snout on the end.
This is why they are not compatible.
If you have a CB and want a 2.2 you have 2 choices. 89+ 2.2 N/A crank, or 89+ T2/T4 Forged 2.2 crank.
Technically you could use a T3 crank as well provided you change the sprocket on the end to a T2 style.
OmniSRT4 is offline
Old 10-16-2003, 02:45 PM   #6
how we all would be lost with out your "anal" and quite blunt sarcastic response.. but i find myself thanking you for your input.. anyhow.. MR. AKUMA
Old 10-16-2003, 03:44 PM   #7
thanks
Uncle Cain
you answered a question for me as well, so the t4 and t2 forged cranks are the same then. so when i go to buy one for my vnt daytona that is all i have to make sure of? 2.2 cb 89+ forged?
thanks again
Old 10-16-2003, 10:59 PM   #8
Re: thanks
thanks again
The T4 cranks have a sprocket on them to run the balance shafts.
Otherwise, they are no different.
OmniSRT4 is offline
Old 10-16-2003, 11:00 PM   #9
Lets take everything personal why dont we.
Fact is, the question didnt make sense.
OmniSRT4 is offline
Old 10-17-2003, 04:31 AM   #10
actually it did... if you read it maybe a few more times... the PRO turbo dodge syndrome might ware off.. and you might understand
:it was simply stating.. can i use an non common block 8 bolt 2.2 crank.. instead of an 8 bolt common block... but after reading other posts about have to ground the snout... info found!
Old 10-20-2003, 08:31 PM   #11
[b]actually it did... if you read it maybe a few more times... the PRO turbo dodge syndrome might ware off.. and you might understand
I am thinking, no.
Its just too bad that isnt what you said.
You said "... can you use an 8 bolt crank or does it have to be.. a 2.2 common block crank? "
You didnt say "can I use a *non common block* 8 bolt crank instead of a CB crank"
The first sentence implies one is 8 bolt, and the other is not.
OmniSRT4 is offline
Old 10-21-2003, 12:53 AM   #12
fine fine i stand corrected...
Tour Management Software | Advertising | Bankruptcy | MPAA | Record Internet Radio with Tags
Page generated in 0.39882 seconds with 13 queries
