10-12-2003, 01:46 AM
Did it on my '84 Laser XE. There's plenty of block material in those holes to tap after you drill out the 10mm threads. I worked for a Chrysler dealer when I did this so I special ordered the MP 11mm tap kit from our parts department for $53. When it came, all it was was a standard 11mm tap and a standard drill bit(I can't remember the size). I was expecting a lot more for $53. The parts guy was nice and didn't make me purchase it. Just went to the local harware store and got a tap and drill bit for around $5! Worked great. No stripping problems(good bolt clamping force) and no headgasket failures. If I were you, I'd get a set of 11mm MP Bolts or ARP Studs, get an 11mm tap that matches those threads, and get the right size drill bit- usually stamped on the tap. To avoid getting metal shavings in the cylinders and water/oil passages, just mask them off with tape, then use a shop vac or compressed air to remove the shavings.
Hope this helps,
Justin Fournier
