11-14-2003, 10:32 PM
Since the piston stops at the top and bottom of the stroke EVERY singel revolution, irregardless of wether accelerating or decelerating, how does letting off the gas affect the rod? RPM and thus piston speed affect the rod, but letting off the gas? I have to disagree.
Remember the air/ fuel mix is ignited BEFORE the piston gets to the top of the bore. When giving it full throttle there is a force pushing down on the piston before it ever turns around and starts to travel down. When you let off the gas at high rpm's the force pushing down on the piston is MUCH less, alowing the full weight of the piston to try to go up without much resistance. Once the rod starts to come down under those conditions, there is a tremendous load going opposite directions- without the combustion smoothing it out.
