11-20-2003, 10:34 PM
rebuild
say bud, here in pa its like 8 bucks a hole. But you add extra for cleaning the block,using a honeplate,decking the top of the block,magna fluxing it for stress and cracks,dressing the rod and main jornals,truing the rods,checking the rods for truenessand cracks. Then you get into the parts of pistons(if it will go .020 over) you might have to go more;freeze plugs,rod bearings,main bearings,and a new oil pump. Did I mention fitting the wrist pins. You should be able to get threw a major overhual of the bottom end around $800.00 to $1,000.00 and know that its been done right with no corners cut. I put $1500.00 into the bottom end of a 360 that screems 6500 rpm and over 500 hp on pump gas.
