Old 11-17-2003, 04:31 AM   #1
Pistons
I came across a magazine article that suggested chamfering sharp edges on pistons, such as in the valve reliefs, stating that the edges could become "hot spots" that could lead to detonation.
Opinions?
supercrackerbox is offline
Old 11-17-2003, 09:14 AM   #2
My Ride: omni glh
Engine: 2.2 turbo
Every little bit helps
I ran a piece of 600 grit sand paper very lightly across the sharp edge of the vavle relief, you don't need to totally radious the corner but just clean off the crisp edge
Did this before the pistons were balanced, then again if your taking off enough to throw off the balance you've probally one too far
glhs636 is offline
Old 11-17-2003, 10:28 AM   #3
turbo600
most people do the same to the combustion chamber as well, but again, not enough to change c/r, just a little smoothing over
Pink Ranger | Debt Consolidation | Advertising | Credit Counseling | Web Advertising
Page generated in 0.29549 seconds with 13 queries
