11-17-2003, 10:06 AM
oil restrictor-which blocks?
My Ride: OMNI GLH
Engine: Chrysler 2.5L
I have my Daytona down for a rebuild, and realized it doesn't have an oil restrictor. The block is stock and original...although it has been rebuilt before. Maybe I lost it then? I've always had fine oil pressure, but am wondering if I should add the restrictor now while it's apart? This is on a 88 Shelby Z 2.2L TII
My 2.5L in my OMNI has the restrictor.
Did all blocks have the restrictor, or just certain one's? Is there a website with this info?
11-17-2003, 07:46 PM
My Ride: 88 CSX-T
Engine: 2.2 T1
Not sure about the years.. I'll see if I can scrape up any info. All I do know is that when I took my motor apart, Gary had noticed that the restrictor was missing. I have always had oil pressure problems since the rebuild. Guess it either got lost or something. When we freshened it up, a restrictor got tossed in, and now I can run nice 10-30 oil and have the oil pressure of 15-50. Just a personal testimonial.
11-18-2003, 03:26 PM
My Ride: 84 rampage
Engine: 2.2L T3
where is the restrictor located?
11-18-2003, 08:03 PM
My Ride: OMNI GLH
I installed the restrictor anyway. Not sure if it ever had one or not. I never had oil pressure problems, but who knows. Guess it can't hurt.
11-19-2003, 04:17 PM
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
anyone has a pic of the block with or without the restrictor installed for referance..... i dont remember any restrictor........
Brian
11-21-2003, 10:34 PM
Engine: 2.5L T2
anyone???
11-22-2003, 12:08 AM
My Ride: OMNI GLH
I don't have a picture, but can explain it. As the block sits in the engine bay with the head removed, you can look to the driver side, and towards the front of the car. You will see a hole, that is a b*stard hole. This is the oil feed to the head. There should be a cup shaped piece in this hole, with a smaller hole drilled in it. It looks about like a small freeze plug with a little hole drilled in it. That is the oil restrictor.
11-22-2003, 10:56 AM
Engine: 2.5L T2
thanks james. hmmmmm i dont remember seeing that when i assembled my motor and i have a little knocking sound..... but my oil pressure is good.... i gotta tear down the motor anyway so ill make sure one is in there. thanks for the help.
Brian
PS where i can i get a few of those (like 2)?
11-22-2003, 11:07 AM
My Ride: 1987 Shelby GLHS 189
Brian,
Your dodge dealer should be able to get a couple for you.
You clear on where it is now, drivers side front corner, right at the corner... when you pull the head, it will become verry clear.
11-22-2003, 06:05 PM
My Ride: OMNI GLH
Thanks for clearing it up Ken....
They are $3.25 a piece. Your dodge dealer should be able to get a couple for you.
11-24-2003, 10:26 AM
#12
Engine: 2.5L T2
Originally posted by glhsken
Brian,
yeah im clear on where the oil passage to the head is...... i just dont remember seeing anything like how the restrictor was described when i built my motor. i gotta pull it apart anyway to check a few clearances and such so ill stop at the dealer and pick some up. thanks for your help.
Brian
11-24-2003, 02:00 PM
#15
Engine: 2.5L T2
Thanks,
Yeah I see the oil hole and I knew where it was at but I dont know what the restrictor itself looks like. The headbolt hole closest to the oil passage looks wierd though....
Brian
