11-18-2003, 12:37 AM
Spun Rod bearing
Ok, I have just spun ANOTHER rod bearing. This engine had been running fine, and no work had been done to the bottom end. It got hot on me in a flash and got too hot before I noticed. The rod bearing spun and it had a VERY VERY slight knock. I was at home, so I immediately parked it.
Pulled the bootom off, and the #3 rod had a little play. Pulled of the rod cap and the crank looks ok. The bearings were toast. I thought I might have caught it soon enough. Well, I put a new set of STD bearings (the ones that came out were the 1988 factory bearings) The #3 still has a little play. The others are tight.
Is there anything I can do short of a full crank pull? can I pull the piston and have the rod resized? Any chance that will work? I don't wanna pull this engine again. But I will if I have to.
Also, if I pull the piston out, do I have to surface hone and put a new ring on it on reinstall? Compression is 150 on it right now.
Any tips or tricks out there?
Thanks
Rescu2000
BTW, this is a T2 bottom end. Forged crank.
Also, I can't be certain, but it looks like there is a mark on the rod bearing cap on that one (#3) that shows the notch for the bearing is in the back on both the ROD and the ROD CAP. I turned it around, so that the notches were on opposite sides. Was this a mistake (due to roundness)????
