Old 11-25-2003, 05:03 PM   #1
forged or billiet crankshaft?
Right now i'm using my stock forged crank for my 400lb/ft 8 valve project. It's only been polished, it should do good.
But soon, hopefully before summer, I want to switch to a 16v neon head. If I reach my goal of 400lb/ft with an 8valve, what do you think is possible with a 16v if I make sure my engine/fuel and whatever else can support it? Would it be a good idea to use a billit crank with anything over 500hp?
theCSXmachine is offline
Old 11-25-2003, 05:15 PM   #2
turbo600
forged cranks are used in engines that make 1000 hp, billet aren't usually used for anything less than 900 hp, of course these are v8's but the metal is all the same. in my opinion, you would be better keeping your forged crank and sending it to 300 below for a cryo treatment, for most parts this doubles its strength and durability. it would also be a good idea to send your block, rods, pistons and head as well.
Old 11-25-2003, 05:53 PM   #3
Thumbs up
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
Billet all the way baby!
dyno sheet
fmic install:
crazymadbastard is offline
Old 11-25-2003, 08:00 PM   #4
I'll probably end up keeping the forged crank... billet is expensive
Old 11-26-2003, 02:17 AM   #5
Stick with forged so you can pony up some money for that fiberglass hood. =o)
Shelby VNT is offline
Old 11-26-2003, 04:20 PM   #6
Oh yeah... i gotta do that before i do neon head, and fiberglass hatch, some lexan windows, paint etc, ****
Old 12-02-2003, 06:27 PM   #7
Re: forged or billiet crankshaft?
Forged and a set of SM performance billet 4 bolt mains.
You wont be breaking that anytime soon.
OmniSRT4 is offline
Old 12-02-2003, 09:03 PM   #8
4 bolt mains...where can I obtain such things?
Chris
mastwolf is offline
Old 12-02-2003, 09:56 PM   #9
Chris
ditto
and how do they bolt up do you have to tap for the other bolts
csxt#10 is offline
Loans | Mortgage | Bankruptcy | Payday Advance | Credit Card Consolidation
Page generated in 0.49301 seconds with 13 queries
