11-29-2003, 10:52 AM
Authorized TD Vendor
if using on your 88 head, you will need to use the cam sprocket from the 88 to match your crank sprocket, and I would also keep the cam from your old head or use an adjustable sprocket as the 84-88 cams/sprockets had a different centerline than the 89 round tooth set-up. Yes, you should change valve springs as a good idea, but definitely have to change the valves. Also not all 782 are crossdriled. The early 782's were not crossdrilled.
later,
Cindy
