11-28-2003, 12:08 AM
About the bolts, you might be better of just getting new ones and saving yourself a possible head ache later down the road. You might be able to get by using them twice, but check them over for signs of stretch first with a fine tooth comb. It usually shows up in the threads as a slight wavey edge rather then a straight edge.
They do make tools for removing spiral locks, but I suppose a screw driver might do the trick. Careful so you don't scratch the piston up, stab yourself, or take a hit in the eye if they spring out. I think they just call the tool a spiral lock remover?
