12-21-2003, 03:11 PM
#22
My Ride: '89 Daytona C/S
Engine: 2.5 T-I
I wouldn't bother with that t-25 either, you could get an exhaust manifold and a mitsu from someone who has'em laying around for a lot cheaper than a custom header and an external wastegate setup, and be confident with 15 psi (but not much, if any, higher)
As for your intake if it is black with an Air Charge Temp sensor it's originally T-II, if it's gray aluminum it's a t-I piece.
If you use the Stage 3 Cal you mentioned earlier you won't need the grainger or diode at all, and I was told the FWD cal's are more 2.5 friendly.
