Old 12-09-2003, 04:32 PM   #1
tall deck 2.5 info
what years does this block come in and/or block numbers so it can be identified. thanks, chris
cj011 is offline
Old 12-09-2003, 05:39 PM   #2
also, can the common block cranks work in these blocks?
cj011 is offline
Old 12-09-2003, 08:27 PM   #3
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
Do you want one? I've got one in my garage that I have no use for...
I'll go and check on the #'s for you later...
Shel-Game is offline
Old 12-10-2003, 02:35 AM   #4
the only problem is that i live in hawaii and shipping would be a bit#h. does only pre-common internals work in these blocks? life would be really easy for me if the common parts worked. thanks for the help.
cj011 is offline
Old 12-14-2003, 08:29 PM   #5
Re: tall deck 2.5 info
87 and 88 TBI motors. Look for the bolt slot on the A/C bracket where it attaches to the head. If the bolt is at the top of the slot, it is a tall deck.
JDIZZ is offline
Old 12-14-2003, 09:14 PM   #6
Location: Down back in the shack with the moon in the door
My Ride: 89 Daytona
Engine: 2.5L TII
2.5 has balance shafts. A common block crank will not work in this block. A noncommon will not work in a common block.
Bad Vibe is offline
Old 12-14-2003, 10:38 PM   #7
okay so the cranks will not work, is the only option for a DOHC motor to go with the neon head route. can i possibly get the cam gears and head off a t3 to work? thanks guys, this info really helps me out.
cj011 is offline
Mortgage | Meble | Loans | Bankruptcy | Record Internet Radio with Tags
Page generated in 0.31862 seconds with 13 queries
