Old 12-24-2003, 09:29 AM   #1
Block fill
Has anybody ever try to partially fill the block on the older 88 down motors for added strength to the block???
turboXE85 is offline
Old 12-24-2003, 10:50 AM   #2
My Ride: 1989
Engine: 2.2 t2
Images: 1
hey I was going to get one my engine blocks filled soon too just to see I have a guy who builds all out race motors alot of the time so he does alot of Hard Bloc I'm just taking mine in so when he doing one of big block block it won't take much to fill my common block, he said a 50 to fill mine
sean is offline
Old 12-25-2003, 02:01 AM   #3
My Ride: 89 Lebaron GT coupe
Engine: 2.5 T2 turbo, I.C.
uhhh, just one pont to consider....the coolant inlet from the water pump is at the bottom of the water jacket. so is the coolant feed line to the turbo...
2Lebarons is offline
Old 12-25-2003, 03:28 AM   #4
filled ????
ravenc is offline
Old 12-25-2003, 09:58 AM   #5
partially filled....with a compound called Hard Bloc. drag racers sometimes use it to improve the rigidity of the block. but its only typically used to fill the lower half of the water jacket, on a street engine. any more than that could cause overheating problems. most V6 and V8 engines have thier water inlets at the top of the block, ours have them at the bottom......which creates a slight problem with using a block filler......
Old 12-25-2003, 08:11 PM   #6
I thought the turbo hoses were like 1/2 way up the block. I don't know about the water pump port. That wouldn't be to good to close off. I'll have an old 86 block out here in a few days. I'll have to investigate a little further. I really don't want to spend the money on this block if it's going to come apart on me. My son and I would like to build a 12 sec. Laser and that is going to take all of 300 h.p. min to do that I would believe.
Old 12-25-2003, 09:39 PM   #7
flitcraft.1
Maybe put in a teflon coated (or something that this stuff won't adhere to) stick to block off the area of the jacket where the feed holes are? So you'd have one section of it that's not filled in at all.
Old 12-26-2003, 09:31 AM   #8
Yea, when I get this block out I'll check it out. I wonder if one of my 2.2 books has a cut away view of the cooling system or the block with the cooling/oil system shown.
Web Advertising | Xbox Mod Chips | Xbox Mod Chip | Bankruptcy | MPAA
Page generated in 0.36693 seconds with 13 queries
