A few months ago, I built up a common block 2.2L TII. While I was at the machine shop getting the block honed with a torque plate, my machinist recommended to replace the oil galley pressed-type plugs with 3/8" pipe plugs. So I agreed and had them drill and tap the holes AND install the plugs with sealer. They are now both leaking oil pretty badly.
Whether they used the wrong sealer, used the wrong material plugs, or simply did not tighten them enough is unknown.
They used STEEL plugs. I can either re-use these or use a softer material- BRASS. I was thinking of using permatex teflon thread sealer with the BRASS plugs and torquing the hell out of 'em. BUT...
What about Disimilar Metals? Meaning BRASS pipe plugs in a CAST IRON block. Are these so disimilar, that oil leaks would likely occur after a few heat cycles???
Would it be less likely to run into oil leaks if I used the STEEL pipe plugs instead?
The way I see it- brass IS a softer material than steel, therefore, it WILL conform to the cast iron block's threads much better...
Anybody have experience with Pipe threads and oil leaks?
Thanks for any info,"thumbs up
