01-03-2004, 01:04 PM
Re: cracked block between frost plugs?
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
Just from the pic, I can tell that neither of those freeze plugs would budge. One is glued in place, the other is the rubber-plug/bolt type. If the water in the block froze, you'd probably get a crack like that. The purpose of the freeze plugs is to push out when the water inside freezes (water expands when it freezes, and can create a whole lot of pressure). If those plugs can't move, you break the block.
I've seen blocks welded before, but I don't know how good a welded block is. You'd probably want to have it checked for straightness after welding. And, it might need to be re-machined if it moves too much.
