Old 01-09-2004, 03:29 AM   #1
perfomance rods
What 151mm rods are the best for racing engine? Aluminium, I guess? If so, where can I purchase them? Or maybe its worth looking for steel rods? What difference in price vs. strenght steel to alluminium?
Regards
Andrius
ebola is offline
Old 01-09-2004, 01:55 PM   #2
turbo600
aluminum are typically very expensive compared to forged steel. i don't think they would make aluminum rods for these engines so it will probably be a custom piece. forged steel is a little stronger than billet aluminum but aluminum will bend more often than breaking, which can save expensive block machining or replacement associated with broken rods. titanium are best for racing engines although it is often more expensive than most people can afford. forged steel rods will work just fine for most applications up to the 900-1000 hp levels (v8), 450-500 hp (I4).
Old 01-09-2004, 05:23 PM   #3
My Ride: 73 roadrunner
Engine: 340 c.i.
I was emailed back info from FM that there aluminum rods can go over 600h.p. and they gave me a price of $520 I do believe.
Super60Dodge is offline
Old 01-09-2004, 11:48 PM   #4
Authorized TD Vendor
glhs727's Avatar
Feedback: (15)
We sell aluminum race rods too. These are high quality GRP rods, not those cheap eagle rods. GRP says they are good up to 800 hp
They are $549 a set, but do include a set of special rod bearings.
later,
Cindy
www.fwdperformance.com
glhs727 is offline
Old 01-10-2004, 07:03 AM   #5
My Ride: omni glh
Engine: 2.2 turbo
If you want to stick with a "steel" rod or plan on driving it on the street alot
Pauter makes an excellent chromoly rod
Very strong, custom done to your specs,
Mine are longer then factory 2.5 tall deck rods yet lighter !
I've been running them for 5+ years know
glhs636 is offline
Old 01-10-2004, 11:15 AM   #6
later,
Cindy
thanks cindy thats the info i was looking for.i decided the other week im gonna use some after market rods so i feel alot safer with what im doing.who had the 4bolt main caps for our cars also.
csxt#10 is offline
Old 01-10-2004, 11:16 AM   #7
how much do these run a set.and what r there rated hp
csxt#10 is offline
Old 01-12-2004, 03:05 AM   #8
Yeah those looks nice too. There are also titanium rods sold for 5.5 hundred per piece....Not cheap. Crome moly is good material for rod I think, Im not going to push my 2.5 common over 300 hp, so it should be ok. Its interesting how much they'll ask for set... I need stock 151 size, pins I can keep the same, can I?
ebola is offline
Old 01-12-2004, 07:04 AM   #9
My Ride: omni glh
Engine: 2.2 turbo
$700 for the set
If forget what he claims on the HP, but it's a hell of a lot more thenI'll ever need
glhs636 is offline
Old 01-12-2004, 12:40 PM   #10
$700 for the set
little pricey i think cindy will work fine.im just want to be safe i want to try to hit as close to 500hp woth nitrous.we will see what else will fail.
csxt#10 is offline
Old 01-13-2004, 07:24 AM   #11
ohiorob's Avatar
My Ride: 83 shelby charger
Engine: 2.4 DOHC
1/4: 10.066
I run GRP alum. rods . I love them. they take a little work to set them up. but its worth it.
ohiorob is offline
Old 01-13-2004, 09:32 AM   #12
Looks like our 5.945 rods are same size as neon SRT-4? Is the crankshaft pin diameter same? Maybe there are more interchangable rods, what can be used for 2.5/2.2 block?
ebola is offline
Loans | Loans | Verizon Ringtones | Debt Consolidation | Guitar Lessons
Page generated in 0.40720 seconds with 13 queries
