Old 01-10-2004, 12:47 AM   #1
HELP: Installing Block Heater
abiba_69
I'm going to be putting a block heater under my hood. Now, i have no idea how to do this so if anyone can help me, that would be very sweet!
Thanks tons!
Chris
Old 01-11-2004, 09:26 AM   #2
turbonut
Drain the coolant. Crawl under the car. You will see a row of freeze plugs on the block just below the head. Take a punch and hammer and tap the 2nd freeze plug from the left on one side so that as you tap on the one side, the other side will begin to pop out towards you. Get some pliers and pull the plug out. Install the block heater.
Old 01-11-2004, 10:47 AM   #3
turbo600
and then refill coolant
Old 01-12-2004, 12:22 AM   #4
abiba_69
Thanks tons! it was mainly just gettting the rite frost plug.. if it even mattered but i thought i'd find out first! Thanks tons guys!
Chris
Old 01-13-2004, 04:11 PM   #5
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
It depends on the block heater design, because due to the design of some block heaters they will not work on the far left or right backside frost plugs, they will only work on the middle rear frost plug hole. Not sure about the two front frost plugs. Clean up the block hole nice and put a little grease on the oring on the block heater and then push it in until it fits good. They tighten the bolt, but not too tight. Good luck.
cawcislo is offline
Novela romantica | Adverse Credit Remortgage | Loans | Bad Credit Mortgages | Submit Articles
Page generated in 0.40623 seconds with 13 queries
