Old 01-13-2004, 03:27 PM   #1
removing head studs for regular bolts
if i removed the heads studs on a block thats new basiclly only been torqued down.could i install new stock bolts in its place with no leaks.it seems like it would be ok but i want to make sure before i do it.
csxt#10 is offline
Old 01-14-2004, 01:44 AM   #2
sure, just make sure you use a new gasket.
tony
macncheese is offline
Old 01-15-2004, 10:23 PM   #3
Yes, one at a time. Torque to the final torque before moving to the next (don't forget to oil the threads). Start from the center in a circular pattern and work outwards. Same as re-torquing a head. Make sure the motor is cold-room temp..
No new head gasket is required.
JDIZZ is offline
Old 01-17-2004, 04:38 PM   #4
a good freind told me the same thing one at a time thanks alot thats what im gonna do
csxt#10 is offline
Old 01-18-2004, 01:24 AM   #5
good stuff!!!!
tony
Old 01-18-2004, 01:44 AM   #6
if they've only been torqued, not driven or anything, u can reuse the gasket and bolts
BuRn__ is offline
Bankruptcy Certification | Guitar Lesson | Credit Cards | Agencia de turismo | Bankruptcy
Page generated in 0.44395 seconds with 13 queries
