Old 01-13-2004, 09:42 PM   #1
Super60 needs specail block?
Turismoman1987
Hey guys, I had a question,, I was reading that in order to turn my car into a super60, that the block has to be I think they said 88 and newer, is that true, I can't use my 87,, and also if it is true,, why?
Thanks alot guys.
Dan
Old 01-13-2004, 09:58 PM   #2
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
You can use any 2.2/2.5 block, prefereably from a turbo application. You'd be better off using the stronger 'common' block which started in '89. You can identify those by the lack of a fuel pump block off plate.
iTurbo is offline
Old 01-13-2004, 10:02 PM   #3
Turismoman1987
So my 87 block is basically out of the question if I don't want to have to worry about reliability problems, or something, right?
Thanks.
Dan
Old 01-13-2004, 10:03 PM   #4
Thanks.
Dan
not unless u want to push BIG power all the time.
BuRn__ is offline
Old 01-13-2004, 10:30 PM   #5
I think an '87 block will do just fine. If you want to push over 300 HP, then the common block might be a little more insurance. I haven't heard of too many block failures though.
iTurbo is offline
Old 01-14-2004, 08:19 AM   #6
turbonut
Your '87 block will be just fine.
Old 01-14-2004, 05:44 PM   #7
My Ride: 1987 Shelby GLHS 189
Agreed... but insurance is always nice.
glhsken is offline
Problem Mortgage | Loans | Bankruptcy | Loans | Car Loan
Page generated in 0.34193 seconds with 13 queries
