Old 01-14-2004, 02:23 PM   #1
Crank swapping for '86 GLHS
Had my engine rebuilt and after about 70 miles or so lost oil pressure. Crank is now bad and needs to be replaced. Fortunately, it's under warranty, but the rebuilder says they can't find a crank core because it has to be the same crank from the same year from the same engine. Is this true? They claim some balancing difference in other year cranks??? Bottom line, I need a crank that will work in my '86 GLHS. Std/Std in good condition so it can be turned 10/10. Let me know what will work and if anyone has one available. TIA
Bodybag is offline
Old 01-14-2004, 05:43 PM   #2
My Ride: 1987 Shelby GLHS 189
ANY 8 bolt 2.2 cranc from 88 down will work FINE
glhsken is offline
Old 01-15-2004, 06:20 AM   #3
My Ride: omni glh
Engine: 2.2 turbo
if you have trouble finding one LMK
I have an '85 std/std with the oil holes radiused and checked for straightness ready to be cut
glhs636 is offline
Old 01-15-2004, 07:43 PM   #4
What do you want for it? My car has been in the shop for 6 weeks while they've been "looking" for a crank. I definately need one to get them going. Email to steve@brotherstrucks.com
and let me know.
Bodybag is offline
Old 01-15-2004, 07:43 PM   #5
Authorized TD Vendor
glhs727's Avatar
Feedback: (15)
Isn't the 85 crank a 6 bolt crank? he needs a 8 bolt. But he can use any 8 bolt 2.2 crank, cast or forged (like t2) crank from 86,87, and 88.
If you can't find one, I'm sure there are plenty of people on the list that have one to sell, or you can buy one, turned and ready to go from FWD Performance.
Later,
Cindy
glhs727 is offline
Old 01-25-2004, 02:29 AM   #6
how much is the shop going to charge you for repairing the car? are they going to pull the motor or pull the tranny and then raise the crank into the car?
cj011 is offline
Old 01-30-2004, 01:09 AM   #7
adam horwatt
is it possible to use an 89 common block forged crank on an earlier block?
Credit Cards | Advertising | Problem Mortgage | eBay | Mortgage Calculator
Page generated in 0.38547 seconds with 13 queries
