01-18-2004, 11:20 AM
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
Rings sound like a good idea, but just use the Mopar stuff for gasket and head bolts, no one has had problems with either, that warrants using better stuff.
01-18-2004, 01:27 PM
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
You'll know as soon as you pull the head....I'd check the exhaust valves for burnt edges too.
02-08-2004, 11:18 PM
Engine: 4cyl. 2.5L
I could be cracked pistons, which in fact would be a better thing since you most likely wouldn't have to put in new rings  I had 2 cracked ones in my motor from last year, and my compression on the worst one was 75 and the other was 110.
Oh and seriously, if you run an MP gasket and mopar head bolts, you will have no problems. I have in all my cars with absolutely no problems, and with one of them I didn't even prep the block and head surfaces properly, just slid the old one out, ran a rag between the 2 and slid the new one in
02-11-2004, 02:19 AM
Authorized TD Vendor
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
If you poured a little oil in the low cylinder and it came up, its rings. You should be ok to just stick rings in unless the cylinder is messed up. After all something caused that cylinder to be low.
walalce
02-11-2004, 09:14 PM
#12
And don't forget to hone the cylinders otherwise the rings will never seat. Use a ball hone, the old 3 finger units don't work as well on smaller engines, I learned the hard way. Rerung a Fox and the rings never seated. Pulled apart, new rings and a ball hone and no more problems. Thank god you can do them in the car easily, "thumbs up
02-12-2004, 12:23 AM
#13
Engine: 4cyl. 2.5L
Well I guess all the local engine shops should change their method?
02-12-2004, 12:36 PM
#14
Well I guess that when I rering in the car, I will hook up the machines they have to get a perfect hone. I didn't realize that older engines don't have perfectly round bores and the best way to get a good hone is to use a ball hone! Silly me, what was I thinking.
