Old 01-30-2004, 01:44 PM   #1
crankshaft weld and regrinds... estimations?
My Ride: 1991 Daytona Shelby
Engine: 2.5L
just like the title says. i am trying to get some rough estimations on prices.
thanks
frank
Frank is offline
Old 01-30-2004, 02:07 PM   #2
My Ride: 1987 Shelby GLHS 507
Engine: 2.2 SOHC Turbo
depending on how bad, i had one done on a 2.2.. who have run about $500.. but it was REALLY bad...
i wouln't get it done, its not worth it...
MoparBoyy is offline
Old 01-30-2004, 03:05 PM   #3
Engine: 2.5L
well this is actually for a non 2.2 application. i want to shorten the stroke by .25". which means each one needs to move in half that so that means weld and grind. my guess is its going to be 8000-1000. that is probably going to be too steep for my blood. gosh the benifits would be nice.
frank
Frank is offline
Old 01-30-2004, 05:16 PM   #4
you could find a unground crank, and do it that way.
Old 01-30-2004, 06:17 PM   #5
If you get it welded I would highly recommend having it nitrided or some other case hardening procedure done to it. That sam motor MoparBoyy talked about threw a couple of rod bearings and trashed the crank. Might not happen to you but Nitriding is not terribly expensive for the extra security.
MM Racing is offline
Old 01-31-2004, 12:57 AM   #6
crank grinding
Frank, Call R.C. Automotive in Capitol Heights.
Roy does custom crank work.
Tell him Mike sent you...I used to work there.
301-350-8408
GLHS0658 is offline
Xbox Mod Chip | Car Finance | Ringtones | Debt Consolidation | Bankruptcy
Page generated in 0.34038 seconds with 13 queries
