Old 02-04-2004, 05:11 AM   #1
t3 head to pre-common block?
okay i am just tossing around ideas. outside of having the intake manifold hit the distributor on the pre-common block, would everything line up the same and yes the pistons will have to be t3's? would the t3 crank gear work in the pre-common block? yes i know that the cast crank is not idea, but with cryro treatment and a tall deck block i maybe able to rest easier. thanks..chris
cj011 is offline
Old 02-04-2004, 10:39 AM   #2
My Ride: 1987 Shelby GLHS 507
Engine: 2.2 SOHC Turbo
should work... if you make a custom intake you can still have the distributor
MoparBoyy is offline
Old 02-05-2004, 02:44 AM   #3
so all the belts and accesories should line up?
cj011 is offline
Old 02-05-2004, 10:29 AM   #4
i would think so, i have never tried it but i don't see a problem
Old 02-05-2004, 06:58 PM   #5
Re: t3 head to pre-common block?
The T3 timing belt pulley on the crank is made for the small snout crank, which only came in common blocks. You can make it work, just not directly.
Dan Culkin is offline
Old 02-06-2004, 05:06 PM   #6
is there anything that you can recomend to resolve this problem? can you clarify alittle more as the differences between the crank snouts.
cj011 is offline
Old 02-06-2004, 05:19 PM   #7
Re: Re: t3 head to pre-common block?
o yeah, i forgot about that.. sorry i've always tossed T1 blocks to the scrap yard and installed common blocks in all my cars :big grin:
the timing belt pulley is differant, you need to install a round tooth timing belt pulley, which isnt really a direct fit like Dan said, i think you can have something machined to fit.. like a spacer.
Old 02-06-2004, 06:27 PM   #8
so the pulley will not directly bolt on. is it because the crank snout is too large, too small in comparison with the pulley? why would i need a spacer? thanks guys
cj011 is offline
Old 02-07-2004, 12:29 PM   #9
Hey man,
No spacer ... the T3 timing belt is wider than the T1/2/4 belt, and is of round tooth design, and was only made for common blocks. The timing sprocket on the crank has a smaller hole in the center (common block crank is thinner there), and of round tooth design. You need to use the T3 specific timing gear, and would need to either machine down your non-common block crank snout, or adapt the T3 front seal retainer to go on to your pre-common block and use a common block crank.
Note that the T3 timing belt has an extra pulley, and also requires a smaller intermediate shaft sprocket. Note that if you wanted to use a distributor to run this engine, it would be spinning 3/2 the rate it's supposed to due to this I-shaft sprocket.
Dan
Old 02-07-2004, 08:40 PM   #10
okay, is there a smaller intermediate shaft sprocket available? also could would a timing belt setup similar to the neon dohc conversion work to get around needing the extra pulley, or any other way around this? t3 crank, 2.5 pistons, tall deck pre common block. that maybe something worth pursueing...thanks guys
cj011 is offline
Old 02-09-2004, 04:40 PM   #11
any suggestions. i am sorry to keep pushing this but i really need to make a final decision within the next week. can i instead use the neon dohc timing gears and use a belt designed for the neon dohc route.
cj011 is offline
Old 02-09-2004, 05:31 PM   #12
The Neon DOHC (and SOHC and 2.4) cam and crank gears are larger, you wouldn't have the right ratio.
You need a T3 specific crank gear and the stock T3 intake cam gear at a minimum (to run the cam sensor). What you play with for the rest is up to you...
Old 02-09-2004, 05:47 PM   #13
My Ride: turbochrysler.com
Just a thought, didn't the early 2.5 TBI cars have a round tooth belt (at least in 88 from what I remember). Not sure if these had the large crank snout, but it might be a possibility if the crank sprocket was wide enough and the right diameter.
Turbodave is offline
Old 02-09-2004, 06:10 PM   #14
Crank sprocket is wide enough, but the teeth aren't cut all the way to the outside like on a T3.
Old 02-09-2004, 06:53 PM   #15
i am sure that the crank snout can be worked about, but what about the t3 having an additional pulley for the timing belt?
cj011 is offline
WoW Gold | Credit Counseling | Loans | Loans | Anime Episodes
Page generated in 0.46051 seconds with 13 queries
