02-10-2004, 10:53 AM
My Ride: 1987 Shelby GLHS 189
The question really isn't when it falls apart, it's when does the power plunge off a cliff.
I know of NO-ONE making enough power over 6k that they shift any higher than that with an 8v. If you are shifting higher, you are not taking advantage of the cars natural torque characturistics.
Most shift a 2.2 by 55-5800 and a 2.5 from 5-5400 rpm. The stock engines are very stout pieces.
02-12-2004, 11:18 PM
My Ride: 85 Shelby Charger
Engine: 2.2 T-II
Originally posted by fishbatman
what i meant by the question, is.. is it a realistic possibility of making an 2.2 with a 9000 rpm redline (for example).
I know i can get it up to about 7500, because that's where we have our 86 jeep at, and it's running the original straight 6.
But why would you want to? Read what Ken said in the previous post. Your power is way done by then. So to answer your quetion, I would say no. It is not realistic.
02-25-2004, 01:20 AM
I can't see anybody ever managing to get the horsepower and torque numbers to equalize in our 2.2 or especially the 2.5 liter turbo engines. To do so you would need some very very serious head porting, or better still a ported 16 valve head. If you go with an 8 valve head, a cam with more lift and duration will help, but there aren't that many readily available options for the 8 valve engines. Doing that will give you more valve over lap and your low end performance will suffer. The 2.2 and 2.5 is a large displacement 4 cylinder (large by automobile standards anyhow) and it's nature is to make more low end power.
Why try and make a peaky powerband, unless you are building a race only engine?
Your kidding, right? Somehow I doubt that the straight six's hp is still climbing or hasn't already fallen off at that point.
02-26-2004, 01:17 PM
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
its the bore to stroke ratio that will make the power fall off even with a high flow head. the 2.5l especially wont rev high cause of the 4.09" stroke..... the piston speed will be too high. you want high revs.... you need a bigger bore than stroke.
Brian
02-28-2004, 12:52 PM
#12
Engine: 2.5L T2
its NOT the valvetrain the limits these motors.... if you bolt on a high rpm valvetrain and a highflow head youll still make no power up on top like a jap torqueless motor. its the bore and stroke ratio that make the motor more geared for torque down low and less revs.
bore bigger than stroke = REVS
stroke bigger than bore (2.2 and 2.5l) = bottom end bliss and less ability to rev.
the 2.2 has more potential to rev than the 2.5l but its still not a 8-9k screamer and it wont be even with a high flow head.
why would you want less torque and more revs anyway.... just make a taller gearbox to match the torque.
if you want a screamer....buy a honda
Brian
02-28-2004, 07:07 PM
#13
Brian
WELL Said!!!
02-28-2004, 08:23 PM
#14
My Ride: 85 GLHT, 87 ShelbyZ
Go look at a Honda motor. They're undersquare just like ours  Why don't they make torque and make hp?? I don't know. Why did my 2.2 like 5200rpm shifts at the track where my 2.5 with the same equipment as the 2.2 had like 5700+rpms?? I don't know that either. Maybe the fact that they're 16v with low velocitiy ports??? Not sure. But they're undersquare. Oh, and the 2.5 has a longer stroke than a 440 Mopar which has a longer stroke than that crappy 454 GM joke.
Later
