02-20-2004, 04:24 PM
Total Seal Rings
My Ride: 89 Spirit ES w/S60
Engine: 2.5 Turbo
Any one used or using Total Seal Rings in our engines?
Wondering what kind of results you're getting.
Thanks,
Marc
02-21-2004, 02:04 AM
Engine: 2.5 Turbo
Gapless was the plan, why not run them?
02-21-2004, 05:16 PM
My Ride: 1987 shelby csx
Engine: 2.4 dohc conversion
i know of a few individuals with very fast cars that swear by gapless and have had no problems that is what i will be running this year.
02-23-2004, 06:39 PM
Originally posted by worrywart
The gases that get past the top ring have no where to go. The gapless second shows a less static leakage, however, dynamic leakage is much worse with a gapless second. When the gases get between the rings it will lift the top ring causing flutter. Dyno tests show decreases in power with gapless rings.
Thats were your wrong. I have numerous articles on the effects of blowby and using gapless rings, one mag even tested an engine using reg rings, dynoed then installed gapless, probably 15% increase in power. Gapless rings make more power, period. Your compression is higher, your oil stays cleaner blah blah blah.
Turbo motors might be a different story but then phone the manufacterers, there the ones who would know! "thumbs up
02-26-2004, 10:11 PM
Heres a link to Total Seal website!
http://www.totalseal.com/howdoo.html
Another link about ring flutter!
http://www.totalseal.com/pg9.pdf
They are using these rings at the import drags, one of the top runners is running 34+ LBS of boost. I found the part # for a 2.5L, #6024. Will find out how much they are tomorrow. I wouldn't mind using them as I have to get my block fixed anyways,
02-27-2004, 07:22 AM
Re: Total Seal Rings
My Ride: 1989 LeBaron GTC
Thanks,
Marc
When I first put my 2.2 together for my white GTC, I used Total Seal's rings. The motor sucked oil like there was no tomorrow. Leakdown testing showed less than 2%. I gave them the benefit of the doubt and ran the motor for 8,000 miles before tearing it down and putting Sealed Power rings in it. Same leakdown, no oil consumption. The oil control ring selected was the SS low tension style. I was using over a quart of oil every 800 miles. The folks at Total Seal were at a loss as to why. They tried to tell me an improper bore finish was the culprit from the start. My machinist is too sharp to make that mistake. In my humble opinion, I'd make a different choice.
02-27-2004, 02:31 PM
#13
My Ride: 83 shelby charger
Engine: 2.4 DOHC
1/4: 10.066
I have been thinking of running ''TOTAL SEAL'' too. I'm glad this thread came up.
02-27-2004, 10:53 PM
#14
02-28-2004, 12:33 PM
#15
Holy sh*t, thats a serious looking engine, nice painting, inside and out. Wow!
