Old 03-06-2004, 01:26 PM   #1
oil pump help!!
after the engine warms up the oil pressure drops to 20 lbs and doesn't like to rise even if you accelerate.it happened suddenly and oil isn't that old. is the pickup plugged or the pump shot or just bad oil.help before i decide to buy a pump for no reason
t1man is offline
Old 03-11-2004, 12:09 AM   #2
My Ride: 89 daytona t1
Engine: 4cyl 2.5 TI
hmm.... having the same problem, starts out with lots of oil pressure then drops once it warms up.....hovering around 15 psi at idle and sometimes it likes to completely loose pressure then get it back all of a sudden. took the pump out today and will check it tommorow. i'll keep you posted on the results.
89 daytona 2.5 T1
rmo64 is offline
Old 03-12-2004, 01:25 AM   #3
Not trying to be rude, but do a search on this subject. Must be hundreds of posts. Most likely you have no problem.
Mike B. is offline
Old 03-17-2004, 10:55 PM   #4
Engine: 4cyl 2.5 TI
found the problem. i spun a con bearing on number 2. sucks i just had that crank ground too. oh well. time to get another crank and some new rods.
rmo64 is offline
Old 03-18-2004, 06:38 AM   #5
did it knock at all mine is about to be opened up but it didn't knock but we think bearings
t1man is offline
Old 03-18-2004, 07:16 AM   #6
My Ride: 1987 Shelby GLHS 189
99% of the time that problem is a loose connector on the oil sending unit.
Sorry to hear yours was the 1 %
glhsken is offline
Old 03-18-2004, 05:27 PM   #7
i have a mechanical oil pressure gauge
t1man is offline
Loans | Ultimate Credit Card Guide | Photoshop Tutorials | Problem Mortgage | Loans
Page generated in 0.31718 seconds with 13 queries
