03-16-2004, 08:18 PM
My Ride: '98 Silverado lifted
Kyle, I have a DAM* good idea! Buy urself a manual, and try and figure it out on ur own, when you cant, ask here. I dont remember it smoking, atleast when I saw it the day before you came and picked it up.....I dont think it has to do at all with the topend (rings piston etc.). Do this. Turn ur key to the *ON* position, then off, then on, then off, then on (3 times) The power loss or some light will start blinking codes. beep beep(pause) beep beep is a 22. A 55 is end or beginning of codes I believe. Lemme know what the codes are, I have a book telling, u can get the codes on www.allpar.com or buy urself a manual, which is what you need to do. The codes will tell ya if there is a map sensor problem, if ur o2 sensor is shot or if any vacuum lines are leaking, etc etc....
Good luck
Dusty
