Old 03-17-2004, 10:10 AM   #1
2.2 rwd ?
are there any differances in the blocks in dakotas if so what are they ? are the bellhousing patterns the same?
2fuzy is offline
Old 03-17-2004, 05:59 PM   #2
My Ride: omni glh
Engine: 2.2 turbo
Bellhousing's are the same
The only difference is one of the boss's on the rwd block is tapped
Yes you can easily tap and use a fwd block in a rwd truck
glhs636 is offline
Old 03-17-2004, 08:32 PM   #3
UnaClocker
Problem with a turbo engine in that truck is the stock intake.. It puts the throttle body and such inside the firewall.. Could be a problem there.. I think a better bet for RWD 2.2 is a mid engine Fiero type setup.. I saw a twin engine Rampage that had that kind of setup in the bed.. Apparently it was very fast.
Old 03-18-2004, 01:23 AM   #4
Thanx was just wondering about ways to play with the daytona thought about the mid engine set up saw a sand rail that was set up with a t1 setup it looked like a blast
2fuzy is offline
Babb Fest | Ringtones | Compare Mobile Phones | Tienda de libro | Loans
Page generated in 0.28594 seconds with 13 queries
