Old 04-15-2004, 09:08 PM   #1
Intermediate shaft bearing
My Ride: 92 Iroc R/T
I replace the large intermediate shaft bearing and it feels like it needs a lot of force to move the shaft by hand.
Is this normal for a new bearing?
Should it go away (haven't fired up the engine yet)?
Shadona is offline
Old 04-15-2004, 11:21 PM   #2
My Ride: 87 GLHS
Engine: 89 CB 2.2
Same thing happened to mine (fresh from the machine shop too!). Couldn't turn it without using a wrench! Which upon further inspection I saw the oil holes weren't even close to be aligned. Saved myself some grief which I'll give back to the owner of the shop in "Person"
They're easy to install, I used the shaft as my "mandrel" and got some longer bolts and the stock cover to "Press" the big bearing in place. Then I did the small one, I had a small sleeve that slipped over the end of the shaft for a spacer (then the bearing)and did the same thing with the cover. Shaft spins very freely now (several turns by itself when spun and let go).
Hope that helps....
Steve St"RACE"ner
It's been fun but I'm outta here!
powermaxx is offline
Old 04-16-2004, 11:42 AM   #3
I installed mine myself...and yes, the oil holes do line up. I can turn it by hand if I hold onto the gear but have to use a considerable amount of force.
Shadona is offline
Guitar Lessons | Online Advertising | Loans | Marketing | Fast Loans
Page generated in 0.29910 seconds with 13 queries
