Old 04-22-2004, 11:40 AM   #1
Another question about Ballence shafts.
My Ride: Daytona base
Engine: 2.5 Turbo
I want to remove the Ballence shafts from my 2.5 turbo. What and where are the holes I have to plug? What do I need.
I also will be doing alittle daily driving with it, but my main daily driver is my other 90 Daytona, V6 5SPD. I am used to alittle vibration. I hade a 89 Dodge Ram 50, Swaped the motor from a 2.0 to a 2.4 and removed the ballence shafts. THe vibration was not bad at all. But It was a different engine that ours. But like I said, Vibration increase was minimum.
Daytona5spd is offline
Old 04-22-2004, 12:45 PM   #2
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
http://www.turbovan.net/balshaft.html
I've removed them from two 2.5 T1 engines. I didn't notice much of an increase in vibration either. The engine revs a lot faster now, which is nice for heel-toe shifting.
iTurbo is offline
Old 04-28-2004, 01:08 AM   #3
Agreed...did the same on (2) 2.5 T-I engines with NO noticeable increase in vibration.
I didn't like putting 7-8 quarts of oil in the motor...so I went with a non-balance shaft oil pan and pick-up. Solved that one.
And yes...sure does seem to rev faster.
Chris Faulk is offline
Old 04-28-2004, 07:50 AM   #4
My Ride: 1989 Shelby CSX
Engine: 2.2 16v Hybrid
http://www.hometown.aol.com/mopartek/balanceplug.html
--scott
scott is offline
Old 04-28-2004, 08:16 AM   #5
--scott
Good idea from Cliff.
I drilled and tapped that hole...then put a hex set-screw down the hole.
Thanks for the link!
Old 05-06-2004, 04:08 PM   #6
The only drawback from Cliffs is that you can't go back and put them in if you want to. I did what you did Chris, drill and tap it out!
Debt Consolidation | Guitar Lessons | Loans | Record Internet Radio with Tags | Credit Report
Page generated in 0.33135 seconds with 13 queries
