I will have the most awesome rings ever in my Turbododge!!!
I am having a custom set of Total seal Gapless rings made in their Chrome-Steel top ring with their ductile moly second and stainless 3 piece oil ring set for our standard
1.5/1.5/4 mm ring package on our engines
cost is about 4 times what a normal ring set goes for...
I spoke to Kevin there and he was very helpful and informative...
I was just afraid of putting the regular Speed pro rings in the hole again, knowing that theay are just cast cheap rings....
Sealed power used to make file to fit rings for our engines, but they have been out of production for over 6 years now... and their aren't any in any warehouse... believe me.. I checked...
I know that these TOTAL SEAL rings will hold up to what I need...
Kevin said they are the only rings that will take the high horsepower/ heat-stress loads of high Boost/ Nitrous together on a small bore...
Also I discussed with Kevin that I was cautious to use a gapped ring (normal-style) because of the possibility of all the extra crankcase pressure that will/could build up with all the blowby that will make it past the rings....
I wanted to run a vacuum pump to pull crankcase pressure out, but I know from experience that you can't run very much vacuum in the crankcase of a wet sump engine before the oil doesn't want to return to the oil pan because the vacuum pulling on the valvecover wants to pull all the oil to the top of the engine....
You can't pull much more than a few inches of vacuum on a wet sump engine before encountering oil return problems....
So... I decided that I wanted a gapless-style ring to counter this blowby-crankcase pressure build up ... Yes, I will still be running a blowby-catchcan-oil seperator off of my valvecover, but no... not a vacuum pump...
RYNO
OMNILET
