Old 05-18-2004, 03:29 PM   #16
Originally posted by gerber1125
pouring oil in what hole in the block
the hole where the distributor goes above the pump
or the hole in where the oil filter goes (where the oil from pump comes up)
thanks, Justin
The one where the filter mounts, where oil comes up from the pump.
lametec is offline
Old 05-18-2004, 03:30 PM   #17
Originally posted by turbovanman
Unless thats what he meant-don't personall know what HEP means, doh! [/b]
HEP = hall effect pickup. Black thingy inside distributor.
With no signal from the HEP, the ASD relay shuts off, killing fuel and spark.
I use the HEP method because it's easier to get the plugs apart. The injector harness plug can be a pain to disconnect, and there's also the chance of the brittle plastic breaking. HEP connectors are soft rubber, no chance of 'em breaking.
lametec is offline
Old 05-18-2004, 03:38 PM   #18
Thanks, nice to know!
Old 05-18-2004, 05:54 PM   #19
now when i pour oil down that hole before i crank it (not start), should i only add say 4 quarts at first and the last quart that way through the hold at oil filter or what?
regular 10w30 right, nothing special down the hole?
Justin
gerber1125 is offline
Old 05-18-2004, 06:01 PM   #20
If its a new motor, just use regular oil. If not, use whatever oil your using for you oil change!
Old 05-18-2004, 06:03 PM   #21
"now when i pour oil down that hole before i crank it (not start), should i only add say 4 quarts at first and the last quart that way through the hold at oil filter or what?"
how much should i put down the hole?
Old 05-18-2004, 06:12 PM   #22
Just fill up crankcase, add a little oil to the filter, remove spark plugs, disconnect HEP, crank engine until pressure shows or around 30 secs. Bang in plugs, reconnect HEP and start car-DONE!
Old 05-18-2004, 06:31 PM   #23
roger
thanks!
Old 05-18-2004, 09:22 PM   #24
When you run a motor with no Oil Pressure, the Oil tends to get HOT and turn to SLUDGE. Another words, you cooked the oil!!
That is where your SLUDGE came from. The first thing any motor builder would tell you is you have to PRIME the Oil Pump.
Can anyone add to this?
Shelby85Charger is offline
Old 05-18-2004, 09:53 PM   #25
[i]The first thing any motor builder would tell you is you have to PRIME the Oil Pump.
Can anyone add to this? [/b]
Check the entire thread!!!!
Old 05-19-2004, 06:42 AM   #26
I did, Justin knows what I am talking about.....Thank you!!
Old 05-19-2004, 07:09 AM   #27
My Ride: CSXT
I hope to god that you guys dont actually do that lengthy process when are just changing your oil...
juxsa is offline
Old 05-19-2004, 12:11 PM   #28
No Sh*t, lol
Fuente De | Xbox Mod Chips | MPAA | The eBay Song | Mortgage Calculator
Page generated in 0.39933 seconds with 13 queries
