05-14-2004, 06:09 PM
Should crank be moving left and right
Ok
when i got underneath my car, i put a screwdriver on the one side of the crank and moved it left a little, found another spot and moved it back right a little
is this normal?
it doesn't move much, but still moves
some spaces look closer together at spots along the crank, while some other seem farther apart, normal? or is there flexibility on these cranks that allow themselves to center themselves once the engine is running?
also, is it normal for a crank to rub against the block somewhat when it is newly rebuilt?
i have a sludge on the bottom of my oil pan, i think there is a small amount of metal in there, cause it is colored a little like metal and small specs are in it, any ideas from what?
arghhhhhhh
