Old 06-22-2004, 07:37 AM   #1
T II Rod bushings
My Ride: 88 daytona
Does anyone know how to remove the wrist pin bushing from the rod. It is a turbo 2 floating piston. I just purchesed a used set and want to replace the bushings but dont know exactly how to get the old ones out.
dantona88 is offline
Old 06-25-2004, 09:15 PM   #2
A bushing driver and a press is the best way. If you take a sharp punch, try to peel the bushing up, then knock it out. Be sure to clamp the rod in a soft-jaw vice.
The machine shop that has to press in the new bushings and hone them to fit the piston pin should be able to remove the old ones for you!
-Chuck James
Stevien1 is offline
Mortgage | Internet Advertising | Advertising | YouTube Proxy | Balance Transfer Credit Cards
Page generated in 0.33382 seconds with 13 queries
