Old 06-29-2004, 07:04 PM   #1
Piston Identification
boostedscooby
I am about to send in my 91 2.5 common block to the machine shop to get it bored and honed. It was originally a junkyard motor that I used to convert my 87 Lebaron from 2.2 to 2.5L T2 intercooled. I have to get the pistons ordered up first. I just noticed that there is a letter 'C' stamped on each of the old piston tops. Does this in any way refer to the piston size? I am hoping that this motor has not already been previously rebuilt and that I can still get it bored and honed. Any help is greatly appreciated. Thanks.
Old 06-30-2004, 08:53 AM   #2
Yes, it refers to piston size.
Stock sizes are 87.5mm. However due to production tolerances, they have 4 "sub-sizes" (all still considered stock size). They're A,B,C and D. A is 3.444" (87.5mm), B is .0001" larger, C is .0002" larger and D is .0003" larger. So each letter after A represents 1/10 of a thousand of an inch.
lametec is offline
Old 06-30-2004, 08:56 AM   #3
My Ride: 1987 Shelby GLHS 189
1 ten-thousandth of an inch. It will not be an issue.
glhsken is offline
Old 06-30-2004, 09:04 AM   #4
Wasn't that what I said? :big grin:
lametec is offline
Old 06-30-2004, 09:12 AM   #5
Yes, I was just clarifying :thumbs up
glhsken is offline
Old 06-30-2004, 07:34 PM   #6
boostedscooby
Thanks Guys! I guess I'll be ordering up some .030 over cast Mahle pistons. Does anyone know if fwd performance ships to Canada? They have a sale on 2.5 litre pistons and rings....$115us for the set of pistons and $69 for rings. I called the dealer and they wanted $150 Canadian per piston.
Old 07-01-2004, 09:45 AM   #7
Yep, FWD-P ships to Canada.
lametec is offline
Old 07-01-2004, 12:09 PM   #8
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
If you're gonna crank up the boost past 15, I'd suggest forged pistons.
LancerShelby is offline
Web Advertising | Mortgage | Mortgage Calculator | Loans | PrePaid Credit Cards
Page generated in 0.34359 seconds with 13 queries
