Old 07-08-2004, 04:05 PM   #1
main studs
turboacclaim
i have a quick question. the main studs you see for sale in FWD performance. do they work on 2.5's or no
Old 07-08-2004, 06:01 PM   #2
more importantly can you run a crank scraper and/or windage with them on a 2.5?
shelbyluvinfool is offline
Old 07-08-2004, 07:22 PM   #3
turboacclaim
well i didn't look when i bought them to make sure they would work. well i put them in the block put the caps on and they have barely any threads showing. so i think i goofed up when buying them without checking first
Old 07-08-2004, 07:49 PM   #4
My Ride: 1987 Shelby GLHS 189
The blocks are IDENTICAL( 2.2 v.s 2.5). I did't assemble my new bottom end (for the 1st time had the machine shop do it) If I recall correctly.. there is an issue with the studs where you cannot sink them all the way.
glhsken is offline
Old 07-08-2004, 07:49 PM   #5
Main studs should NOT interfere with a scraper.. I installed one on my new block
glhsken is offline
Old 07-08-2004, 11:43 PM   #6
turboacclaim
i had the studs all the way down. put the three middle caps on and they on stuck through the cap with the washers on maybe a 1/4 of a inch
Old 07-08-2004, 11:51 PM   #7
well, that's not good. I just ordered some main studs and rod bolts!
Old 07-08-2004, 11:52 PM   #8
turboacclaim
i am not trying to stop people from buying them. is there just something i am doing wrong. the end caps were fine. it was just the three middle ones.
Old 07-09-2004, 01:28 AM   #9
The ones they sell are actually for non common blocks. You can ask Cindy when you order them for longer ones for the common block.
I know that isn't a lot of help, since you have them already, but maybe she will exchange them for you.
-Kyle
MachineHead is offline
Old 07-09-2004, 02:10 AM   #10
turboacclaim
i really hope so is there a good chance they will
Old 07-09-2004, 10:13 AM   #11
My Ride: 2000 GMC Sierra
Engine: 5.3L V8
I had the same problem. This is what I did:
I put the center cap on, and only screwed the stud in enough to where it would be flush with the end of the nut (wish the washer installed as well). This means that the outmost 2 studs have more of the stud in the block than the inner ones.
It's been this way, my car runs great, and I've got over 3000 miles on the new motor so far with no problems.
cybermrc is offline
Old 07-09-2004, 10:31 AM   #12
how much stress are you putting on it though, i.e. boost rpm? I don't want to take any chances. It kind of defeats the purpose of using HD fasteners if they don't clamp down!
Old 07-10-2004, 07:59 PM   #13
NO Democracy!
Like someone mentioned.... there are early block studs, then there are common block studs which are a bit longer. Cindy needs to have this clarified on her site if she hasn't already to save future problems.
DirectConnection is offline
Loans | MPAA | Mortgages | Halloween Costumes | Loan
Page generated in 0.46512 seconds with 13 queries
