07-20-2004, 05:08 PM
#23
My Ride: turbochrysler.com
Originally Posted by gilpatt
OK so you guy's are saying it should work if I put turbo pistons in it and the crank, rods and block should work. Is there any difference between 2.2 turbo pistons and 2.5 turbo?
I'm also wondering if the rods will need to be changed to turbo rods from a 2.2 turbo
The weak link in your system is really the rods. The pre-common block 2.5's like yours used longer rods than a 2.2 or newer 2.5 so swapping in the beefier rods from one of them wouldn't be an option. Custom rods could be made but that gets pretty pricey.
If it was me I'd take my chances on the stock rods and see what happens, if one lets go it will probably take out the block too, and then it's time to decide on something different. But, depending on luck and how you treat it, it could run forever on the factory rods.
