07-21-2004, 07:53 PM
safe compression readings
only 93 miles on motor. ive checked compression at 10,64,80,93 miles. checked religously, anyway the readings have been 115 on all, every time.
i did a dry and wet test back to back today, cause i was told my compression was low. 115 dry and 140 wet.? are they not seated, or are they washed out from being rich? i have turned down my f. press to about 30 psi at the 64,80 mile mark cause the plugs were sooty. they are clean now, but when the motor is warmed up for a while it will smoke when revved(in nuetral) slightly. is this cause for concern or just drive it? this same motor before cracking 2 pistons at 22 psi (stock pistons) was 130 psi until about 1200 mi. then it was 140 ish. nothing changed except .020 over with venoilas.
would the larger bore and 3cc deeper dish cause this lower reading?
im afraid the turbo, valve seals, or rings are leaking. the head(reconditioned with seals and guides) and turbo have 1600 mi. on them.
any ideas, thoughts or comments? any help is very much appreciated.hate to take all apart a third time lol.
07-22-2004, 10:00 PM
My Ride: 2000 GMC Sierra
Engine: 5.3L V8
How did you break the engine in initially?
07-25-2004, 04:46 PM
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
My common block 2.5 0.020 over venolia's seated nicely, but my compression was too high I think. I just did compression check last week after about 6000 miles. 130 all the way across except one cylinder which was 128. Compression check was done with motor at operating temperature. I pulled all the plugs and did a cylinder at a time. I let the car crank over 3 or 4 times with the gas pedal to the floor. Car ran perfect at 12 psi no detonation or anything. With stage 5 at 15 psi graingered I had detonation so I just swapped in a head shim yesterday. I'll do compression readings later today and let you know what the new compression is.
07-25-2004, 05:03 PM
My Ride: 1987 Shelby GLHS 189
Compression of up to 150 is perfect. 130 is no where near too low. 115 is getting there.
Yes, Considering you added 3cc's to a 15 cc dish, I think it would have a LARGE impact. You added 20% to the dish volume.
07-25-2004, 07:24 PM
Well, I said I would post compression readings after new headgasket and copper shim. old readings were 130,130,130,128, new readings, 130, 135, 134, 130. Go figure, with the shim I gained compression in some cylinders, probably not, the headgasket is probably just sealing a little better now. Again readings will probably vary between guages, due to all kinds of factors and how the compression test is performed, etc.
07-26-2004, 01:32 AM
My Ride: 87 Shelby CSX
You guys should feel really good! I've got 85% leakdown on my 4th cylinder
07-26-2004, 02:32 AM
Engine: 5.3L V8
Originally Posted by adam89shlbydayt
just the usual 30 minute start up. then on a back road do like 30- 50 mph blasts, on and off the throttle. then drive it normally, not abusing it. only seen 6-10 psi very breifly. though the stage 5 was extremely rich. the fuel is down to 30 static.
everyone is telling me to just drive it. the ring end gaps were set at .019 for the top and .017 for the second. the piston clearance was set at .007 so they are noisy at first.
You say it was running extremely rich; that kind of worries me. Sounds like you broke it in correctly, but the running rich part is very bad for ring break in. Your ring gaps are good. I set my upper at .016 and lower at .012 I think? Not sure on my piston clearance, but I'll bet it is similar to yours.
My cranking compression was like 165-175-175-180 when I last checked (!).. kind of high I thought, but I am not worried.
Give your rings a chance to break in. Some take up to 1500 miles! Sounds stupid, but it's true.. If after x amount of miles you show no improvements, and you are certain your cam timing is correct, etc, I'd consider new rings perhaps. But I think you'll be alright. Just stick with it.
08-02-2004, 11:39 PM
#13
Engine: 5.3L V8
Actually a worn out cam will show no ill effects on compression. It will read normal compression readings.
I had a Dakota 2.5L that had a cam broken in half once (didn't know it at the time I checked compression); and I checked compression on all 4 cylinders and all were normal. Later on of course I figured it out; what a pain. Sometimes the answers to the most difficult problems are the simplest.
#14
Engine: 5.3L V8
Glad to hear your rings broke in!
