08-01-2004, 01:24 PM
Originally Posted by Koreth
if your going to destroke a 2.2 to to 2.0 and slap a neon head on it, wouldn't simple be less time and trouble to simply slap a neon powertrain into your TD?
The Neon 2.0 is a weak motor with a short deck and a not so ideal rod ratio.
Actually you would be best off installing a 2.4 with a 2.0 crank and custom length rods/pistons.
Howver, the fact is, destroking your motor is pointless. You dotn hve have acces to variable valve timing so you are limited toa single cam profile. If you put a cam in big enough to work with the 2.0's RPM range, it will not idle and will run like crap at anything other than flat out. If you use a stock or a mild cam, then you will be wasting the extra thousand rpm's worth of power. You would be better off with a properly built 2.2 with a 16v head and aftermarket cams. The stock 2.2's stroke has no problem running 7k rpm with the right setup which is the limit of any streetable cam profile anyhow.
In my opinion, since we do not have variable valve timing to work with, we need to stroke the motor to a level in which it runs out of breathe at the same time a as single cam profile, thereby maximizing its power output with the current bore size.
