Old 07-25-2004, 03:45 AM   #1
88 t1 with 6 bolt crank?
My Ride: 87 Shelby Charger
Images: 8
Scrapping my 86 s.c., pulled engine and dropped the pan today, block is 88 but has a 6 bolt crank in it. I also have an 87 block, but that has the 8 bolt. Werent 6 bolts dropped in 85? Someone must have put the 6 bolt in, is one tougher than another? The 87 has a 5 bolt crank pulley, the 88 a 4 bolt. The 88 also has the 287 head with an 88 cast mark, werent these heads only 85?
Anyways, just wondering...
boost geek is offline
Old 07-26-2004, 05:26 PM   #2
is the head a roller rocker one?i have a 287 head that i think is a RR head but i may be looking at it wrong.
TurboShadowES is offline
Old 07-26-2004, 11:23 PM   #3
Images: 8
No, it`s a slider cam, followers are very worn out but still made decent power...
Old 07-27-2004, 01:43 PM   #4
My Ride: turbochrysler.com
Sounds like an 85 or older crank in your 88 block I don't think it's any stronger or weaker than an 8 bolt crank.
As far as the crank pulley goes 88 and newer got a 5 bolt pulley, your 87 should have a 4 bolt pulley but I'm goning by model year, so if the block was made late in 87 it probably came out of an 88 vehicle and had the 5 bolt pulley.
The 287 heads were still made a few years after they stopped putting them on production vehicles so it could have been a replacement part, I think I remember the carb cars getting the old castings for a few years longer than the others as well. My GLH has a MP ported head and it is a 90 casting 287 or 445 PN head (can't remember which). All the MP heads I've seen have a little heart cast into the machined area above the temp sensor.
Turbodave is offline
Old 07-27-2004, 02:24 PM   #5
My Ride: 88 Shadow
Feedback: (7)
Yeah the 88' motor probably threw a rod, scoring the crank. So they just found one at a junkyard in decent shape and threw it in with the flywheel from the same engine.
moparzrule is offline
Loans | Mortgages | Buy Anything On eBay | Mortgage | Online Loans
Page generated in 0.43047 seconds with 13 queries
