Old 08-04-2004, 12:15 AM   #16
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
I was pretty sure that if a motor was honed on a machine built after 1970, the rings should seat within one or 2 heat cycles. Mine did. Two heat cycles on my current engine and my compression was 160 across the board
contraption22 is offline
Old 08-04-2004, 01:02 AM   #17
chatterx
ahhh yes but with gas getting past the rings it may be causing them not to seat
Old 08-04-2004, 01:02 AM   #18
My Ride: 90 stang, 86 stang
Engine: T.T521", nitrous351w
"I was pretty sure that if a motor was honed on a machine built after 1970, the rings should seat within one or 2 heat cycles. Mine did. Two heat cycles on my current engine and my compression was 160 across the board"
what rings u using?
igotaneed4speed is offline
Old 08-04-2004, 01:31 AM   #19
chatterx
if the ring question was directed at me I am using the federal mogul (sp?) rings
it wont hurt anything if I unhook the turbo for a few hundred miles to try to help the rings would it
Old 08-04-2004, 07:55 PM   #20
folding hands.....
My Ride: 1987 shelby charger
Engine: 2.2 t1/t2 conversion
stumbling and missing might be because of cam.......if it were me i'd ignore it for now....
in my honest opinion....i would run the thing for awhile....
and i would.....after break in.....run it hard.......
if she is loose....loose can be fast...and if she is tight....tight might loosen with use.......it happens
when im looking at a JASPER alternative....im gonna run her rough,tough and tumble.....and if she blows.........she blows......
of course if you have $2000 pistons and rods..and a new forged crank......and you are worried ....tear it back apart.......
eef
eef mcglikn is offline
Old 08-05-2004, 01:29 AM   #21
kooterskkar
Depends on what you mean by "unhook". I guess the easieat way is to bypass it for a while. Or you could just lower the boost back dow to say... 5 lbs for a while. If you want to bypass it just run the intake pipe straight to the throttle body instead of through the turbo and ic first.
What I would do is tear the engine back apart, and check everything there first.
Loans | Payday Advance | Car Credit | Mobile Phones | Loans
Page generated in 0.35560 seconds with 13 queries
