08-03-2004, 12:45 PM
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
how much later is it shifting... outside temp can effect when the trans shifts... was there a change in temp since the mods?
what do you mean by "not working in neutral"?
if it moves more, then your motor mounts are prolly kinda beat. check them for tears.
cool engine... like where on the gauge? mine ususally runs 1/4" from the line above the "C" and thats at around 195 on my scanner at that point. did you replace the thermostat?
everytime the car needs maintenance or a part replaced doesnt mean that the car is trashed and its time to get a new motor, or to junk it etc...  keep on driving it and working on it.. good luck
Brian
08-04-2004, 01:03 PM
Your trans woes could be he misadjusted the kickdown cable or knocked it around when doing the repairs. Recheck the adjustment and yes, as Brian said, maybe the motor mounts finally packed it in.!
08-04-2004, 08:55 PM
Engine: 2.5L T2
hey Pimpedaries....
i saw your other post about the 2nd gear not working and the car moving forward in neutral... does the car also try to move forward when the car in park and stuff? if it does the valve body is all clogged with metal.
Brian
08-08-2004, 12:54 AM
Originally Posted by Aries_Turbo
hey Pimpedaries....
Brian
Well here is what is happening now -
When in park - car stays parked and all brakes lock up - ok
when car is in reverse the car acts as if its in neutral, but makes then motor lock up and will not go forward, BUT when i shift it from park to reverse the whole engine litterally looks like its going to plant itself in the firewall
Motor mounts are good
When car is in drivve it will no longer shift into 2nd gear and when you try to manually when using the "1" "2" it will not shift, just stays in drive and 1st gear, now here is where is gets kinda odd, the exhaust is nnow puttin out some really nice black smoke when im revvin it trying to get it to hit 3000 RPM, yet still will not hit 2nd gear or go over 2500 rpm.
My friend told me it was the Torque Converter jsut beside the tranny pan, so i WAS going to take a quick look at it to see whats what, but wont do it until i get your adivse guys.
Thanks for all the help so far, you guys have been great.
08-08-2004, 03:34 PM
Well, the pain a suffering is over, the car is now to be sold as is no warranty for parts and for fixing up if they want to, gutted the tach, audio system and a few other toys, im sellin it for 500 as is, tranny bad, but that is all it needs to get it back up and running. Il be getting a 2002-2003 Mitsubishi Lancer EVO Or the Eclipse - nice cars, lotta cash. anywasy thanks anyways guys, the pain is over.
08-09-2004, 12:33 AM
Engine: 2.5L T2
NNNNNNNNNNNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOOO you cant go over to the dark side of RICE! Get a turbo driveline and swap it in.
Brian
08-17-2004, 11:32 AM
Engine: 2.5L T2
yup im with maurice.... i wont buy any car with any signs of NOS on it. its a recipe for disaster.
Brian
08-23-2004, 10:50 AM
#13
peer pressure is a powerfull thing eh?
Oh one thing about the Civic SI hatchback . I raced one.. a 2002.. and beat it.. bottom end, and on top end..he couldnt even touch me and my, SUZUKI SWIFT tops out at 110MPH!!
So yah.. you might want to choose the integra..the other, not QUITE as slow car.
_________________________________
1989 LeBaron Coupe|2.5L Turbo I Auto
Under Restoration..and then some!
http://www.cardomain.com/me
mberpage/420349/1
08-24-2004, 08:22 AM
#14
Engine: 2.5L T2
ok, if you are going to be a ricer... i suggest one external mod for those cars.... an eaton M90 or an eaton M62.... these cars have 0 torque but tons of high end.... positive displacement blowers add much needed torque and dont hinder the high end.
Brian
