Old 08-03-2004, 10:57 PM   #1
will it blow again??
My Ride: 91 'Tona Shelby
i have a 91 shelby daytona 2.5L aftermarket Garret turbo, intercooled, K&N filter, turboXS BOV she blew on me about a week ago. fried a couple pistons and gave it a lower rod knock! i dont know why and need too. now im swapping with an 89 shelby 2.5L turbo. if i put the bigger garret on the new engine will it blow again????? i need reliability cuz im going to college soon. heh HELP! i will keep the intercooler and BOV also. i just need to know if shell blow on me again and why it did in the first place. i was thinking maybe the boost is set too high. 15 psi too much?
orion is offline
Old 08-03-2004, 11:02 PM   #2
Feedback: (7)
Whats your air/fuel gage say at 15?
gakali is offline
Old 08-04-2004, 01:48 PM   #3
dont have one yet, but will within the week.
orion is offline
Old 08-04-2004, 02:01 PM   #4
You just answered your own question. HOw do you know what your air/fuel was at 15 psi, you probably went lean and melted or detonated it to death. How did you get 15 psi???? Factory cutout is 14.7 psi????
Old 08-04-2004, 04:09 PM   #5
My Ride: 91 Spirit R/T
Engine: TIII
The only thing I would be concerned about is the turbo. Every engine I've seen that has had a spun bearing or a bad main/rod bearing knock the turbo has gone out within 2000 miles after the new engine is put in. Little bits of metal get into the oiling system and end up in the turbo bearing and ruin it.
I just tore down a turbo that this happened to. The shaft didn't look pretty. The turbo itself only had 1200 miles on it, then a rod bearing spun. Rebuilt another engine, installed it and the turbo went out 400 miles later. Several turbo rebuilders that I've contacted said this is a common occurance for the reasons stated above.
With the new engine make sure that you get and monitor an A/F ratio gauge possibly even have an EGT installed with the engine. Then you'll know if you have enough fuel and won't damage your pistons.
86Shelby is offline
Old 08-05-2004, 12:41 AM   #6
if you dont have an A/F gauge, just hook up a digital multimeter to the O2 signal wire in the meantime. you've probably got one of those, right??
iangoround is offline
Old 08-05-2004, 01:53 AM   #7
kooterskkar
Which is why you get a seperate oil filter for the turbo. Ive ben looking at some synthetic oils lately, AMSOIL seems like a good company. Might want to check out a few of their filters. AMSOIL bypass filter
Old 08-05-2004, 06:38 PM   #8
much appreciated!!!
orion is offline
Old 08-07-2004, 07:18 AM   #9
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
Originally Posted by Shadowlord
where do you get an extra filter what does it look like and do you install it on the oil feed line to turbo?
thanx
TU has them. RP may still have some stock left.
John B is offline
Old 08-11-2004, 03:46 PM   #10
TU? RP? who are they?
orion is offline
Old 08-11-2004, 04:10 PM   #11
TU- www.********************
RP- www.relentlessracing.com
also try www.fwdperformance.com
Books | Loans | Advertising | Payday Loan | Mortgage Calculator
Page generated in 0.40293 seconds with 13 queries
