08-06-2004, 11:10 AM
Lifting the head under boost...
My Ride: 88 Dodge Shadow
Engine: T-III Power
the car runs and drives perfect....
however, if i make a pull down the road the temp shoots right up to about one mark before "overheating" on the stock gauge. if i drive around for a little bit, the temp will work it's way back down.
before getting on it the car doesnt smoke, but once you go out and make some pulls it will smoke just a touch of white for a little bit afterwords... however, the next day it'll be just peachy untill it gets under a decent load.
it's either got to be a slightly blown HG, or it's lifting the head under boost.
i'm currently running ~22psi. i bought new 11mm felpro head bolts, and tapped the block for them this last time around. i'm also using a felpro HG, which i know is a "no no" ... but i had one laying around, so i used it. i'll take it apart here shortly and find out if it's blown or not.
my old setup was lifting the heads at ~20psi... which is why i went to the 11mm head bolts.
basically.... what can i do to fix this? will the ARP bolts and the mopar gasket stop this? can i get away with just the mopar gasket? (i'm on a budget untill i get the trans am back up and running)
thanks in advance
chris...
