Old 08-09-2004, 02:10 PM   #16
My Ride: 1987 Shelby GLHS 189
No, That is a different mod. Joe O'Conner's. That is NOT a street car.
basic mod is drill and tap a hole in the waterpump housing AFTER the impeller. Run a line up from it to the Drivers side of the head. Pumps COOL coolant into that area.
glhsken is offline
Old 08-09-2004, 02:25 PM   #17
The coolant does not circulate enough around cylinder #4, it gets hot and hotter.
When the modification is made the coolant is taken directly from the water pump to the side of the head, sending cool water to the #4.
It only affects the head cooling, so I do not think the car will heat up slower or faster.
You probably will not notice.
-Bryan
DakotaKid is offline
Old 08-09-2004, 02:29 PM   #18
-Bryan
So if it doesn't make a difference-why do it?
Old 08-09-2004, 02:39 PM   #19
Are you kidding me?
Reread what I posted.
Old 08-09-2004, 02:40 PM   #20
Re-read what Bryan wrote...
glhsken is offline
Old 08-09-2004, 02:55 PM   #21
Feedback: (7)
The way I understand it, because of the way the coolant passages are in the head, the back side of #4 doesnt get as much coolant flow by it as the other cylinders, causing that cyl to run a bit hotter. Even when the stat is open, the coolant flows in the path of least resistance - straight through the stat kind of bypassing #4. Of course there is flow by #4 just not as much as the others. Under extreme conditions with all else being equal, #4 is likely first to see the highest combustion temperatures. I think it would be best to run the 195 stat with this mod because the flow bypassing the stat. would definately make it run cooler. Makes sense to me but I doubt I'll do it.
gakali is offline
Old 08-09-2004, 03:16 PM   #22
Are you kidding me?
Ok, sorry, my bad, lack of sleep, your saying it won't make a difference in the way it heats up, correct!
a 1000 apologies.
Old 08-09-2004, 03:21 PM   #23
O'Conners method WOULD make a difference. Gary's would not as is it still t-stat controlled
glhsken is offline
Old 08-09-2004, 03:33 PM   #24
I will try the waterpump to head mod as described when I change my engine!
Old 08-09-2004, 03:45 PM   #25
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
hey ken, what size line is recommended and at what point on the head is recommended? near the freeze plug? anywhere in particular. thanks
Brian
Aries_Turbo is offline
Old 08-09-2004, 04:09 PM   #26
Reeves Knows all that stuff. Actually not a big line.. 1/4" or 3/8". Reeves used braided. I know which side of the cam center is important, not sure which though. I know on my head it's towards the TB.. But I know 1 was set up off.. Not sure if it was mine
glhsken is offline
Old 08-10-2004, 09:40 AM   #27
Engine: 2.5L T2
thanks ken... can you have reeves shoot me the details or a pic or something? thanks
Brian
Old 08-10-2004, 11:00 PM   #28
kooterskkar
Thats why you ditch the thermostat all-together.
Old 08-11-2004, 12:10 AM   #29
My Ride: Reliant
Engine: SOHC 2.5 8V
I have no stat, running cool was never a problem with the Reliant... in the past anyways.
gdonovan is offline
Old 08-11-2004, 08:01 AM   #30
We're talking about street cars I thought. I sure wouldn't want to run down the road without a t-stat.
glhsken is offline
Best Credit Cards | Восстановленное медицинск | Credit Cards | Bad Credit Mortgages | Remortgaging
Page generated in 0.42695 seconds with 13 queries
