08-11-2004, 10:04 AM
#31
WEll...
What about what I did.... I drilled and tapped a hole on the end of the cylinder head and installed a "T" where the bottom of the "T" has a 3/8 pipe thread that screws into the cylinder head on the #4 end.... The other two sides of the "T" are -8AN that I use as a water coolant line coming from my turbo that go into the fitting at the bottom of the water box.... so, all the water is still controlled by a thermostat, same as before, but I feel that this outlet for the hot #4 water in the head should work fine.... if it is hot, it should push out into the turbo water coolant line....
WHat do you guys think?
I do know that the fitting in the head is larger (3/8 pipe) and has a larger internal hole than the rest of the turbo cooling system, which is 1/4 pipe to -8an....
I have blocked off my heater hose fitting on the bottom of my water pump housing with a 3/8 pipe plug, so I guess I could always just do the mod where I run a line from the water pump housing up to the side of the head where I already have it drilled and tapped for my "T" fitting....
It does look clean there on the side of the head though...
ANy ideas?
RYNO
