Old 08-09-2004, 09:44 PM   #1
crank cog HELP!!!
ok, my 5 crank pulley bolts were rounded off (STUPID 12 PT BOLTS!)
Anyway, used an angle grinder to grind them all the way and knocked of the pulley. (I love new tools! LOL)
How does the crank cog for the timing belt come off? These bolts don't hold it on, right? Isn't it just woodruff keyed or something? Can't tell it's dark outside!
shelbyluvinfool is offline
Old 08-09-2004, 10:53 PM   #2
Has a big nut in the middle too I believe.
1985ShlbyChrger is offline
Old 08-09-2004, 11:09 PM   #3
ok, I just checked it, and that bolt is long gone, so I should just be able to wiggle/pry it off? Just want to make sure none of the pulley bolts do anything else!
THANKS!
Old 08-09-2004, 11:31 PM   #4
yer gonna need a gear puller...one zzat uses bolts instead of jaws...bolt it to the holes for the pully bolts and just crank it off....easy peasy
Gus A Wiey is offline
Old 08-10-2004, 12:12 AM   #5
no-can-do...bolts still in the holes...had to grind the heads off of them!
Old 08-10-2004, 12:22 AM   #6
Feedback: (7)
If it make you feel any better you only need to get 3 of them out to use a puller. They should come out easy.
gakali is offline
Old 08-10-2004, 12:26 AM   #7
hopefully, I can get a grip on the bolt shanks, and twist them out...we'll see!
Old 08-10-2004, 12:31 AM   #8
Feedback: (7)
Unless their seized in theres nothing holding them in without the bolt heads.
gakali is offline
Old 08-10-2004, 12:37 AM   #9
no, I thought they were originally seized, since 230lb-ft from an impact wouldn't break them loose, just stripped the heads. Iit was the pulley holding them back. The threads just came right out. THANKS!
Old 08-10-2004, 12:45 AM   #10
Feedback: (7)
Remember...righty tighty lefty loosey!
gakali is offline
Old 08-10-2004, 12:47 AM   #11
you left hand is the one that makes the "L"
LOL
Thanks for the tip!
Old 08-10-2004, 02:05 AM   #12
kooterskkar
Get a bolt extractor.
Bad Credit Mortgages | Myspace Layouts | Car Loan | Online Advertising | Cheap Loan
Page generated in 0.75667 seconds with 13 queries
